Running Drills
Running drills are an important component of training, especially if you are new to the sport, in order to improve technique, coordination, speed, and economy.  The exercises include exaggerated components of a running stride that activate both primary and stabilizing muscles in all planes.
ACCELERATIONS
A structured effort designed to build speed progressively in distinct increments over a specified time period.
  • Effort: Over a specified time interval, increase your intensity in specific steps from a moderate effort (RPE 4, Zone 2) to a high effort (RPE 7, Zone 4b).
  • Objective: Focus on building pace incrementally rather than continuously, ensuring clear transitions between effort levels.
  • Form Focus: Maintain a relaxed posture, with controlled arm movement and an efficient stride pattern as the effort increases.
  • Recovery: After each interval, recover for a specified time interval at RPE 2 (Zone 1), ensuring your heart rate stays below 70% of its maximum.
BUTT KICKS
The goal of this drill is to pull your heels up to your butt (glutes), just as it sounds.
  • Take short to medium length strides while using your hamstrings to bring your heels all the way back to your glutes.
  • If you find that your quads are too tight and you can’t quite get your heels all the way back, we recommend stretching your quads to increase your range of motion.
CARIOKA
This drill requires you to move laterally, so you will need to face sidewise to your intended direction. For the purpose of the description, we’ll have you move to the right, but we expect you to complete the Carioka drill in both directions.
  • Begin with your feet about shoulder-width apart. Drive your left leg up and across your body and plant your left leg right adjacent to your right foot.
  • Step your right foot to the right so it is parallel with your left leg again (at this point you should be positioned in the same direction and orientation that you were at the start).
  • Next, swing your left leg behind your right leg, again so it lands on the right side of your right leg.
  • Then bring your right leg back across your body, once again ending up in the starting position.
  • This is 1 rep. Complete 5-10 reps and then reverse direction (and legs) and do the same number of reps on the return.
HIGH KNEES
Taking short to medium length strides, drive your leading knee up high enough so that your thighs are parallel to the ground. If you can bring it up higher, all the better. Do the same with your alternate leg and repeat. Focus on executing the form, not on doing this at a quick pace.
KICK/KICKING
When a workout description has “kicks” or “kicking” in the title, finish the marked intervals with an all-out sprint.
SKIPPING
Yes, just like when you were a kid! Except now you want to focus on swinging your arms at your sides like you would when running, not across your body like most kids do when they ski
STRIDES
A steady increase of speed over a specified distance, designed to improve leg turnover and running form.
  • Effort: Gradually and smoothly increase speed throughout the stride, starting at an easy effort (RPE 3, Zone 2) and building to a hard effort (RPE 8, Zone 4).
  • Objective: Aim to increase speed with every step so you reach maximum speed by the end of the stride. You should achieve this by gently increase stride length with every step, while maintaining a constant high cadence
  • Form Focus: Keep your shoulders, neck, and jaw relaxed while maintaining controlled and efficient running form. Pay attention to smooth transitions in speed.
  • Recovery: Walk back to the starting point after each stride for a specified time interval at RPE <2 (Zone 1), keeping your heart rate below 70% of its maximum
Looking for Training Advice?
Are you trying to decide what training plan to use or how to plan your race schedule?  We have some resources available:
Check out the Blog!  Turn to the Wahoo Sports Science team for the best training advice.
Join the conversation in the Forum.  Join our community of like-minded athletes to share training tips, advice and more.
