Using a Wahoo Smart Trainer with an App on Apple TV
To use your Wahoo smart trainer with an app running on Apple TV (ie. Zwift, Fulgaz, etc.) paired over Bluetooth®, follow the steps below:
  1. Download and install your preferred fitness app on Apple TV.
  2. Turn on your Wahoo smart trainer and make sure other devices with Bluetooth® Low Energy (LE) are off.
  3. Log in to the app, go to settings, and connect your trainer as either a controllable trainer or a power meter.
  4. Pair one* additional sensor (e.g., cadence or heart rate).
  5. After your workout, unplug your Apple TV to prevent interference with your trainer in other apps.
*Note: Apple TV can only connect to two sensors at once, including the trainer. Consider using a two-in-one sensor like the TICKR X for both heart rate and cadence data simultaneously. While you can pair more than two sensors, only two can send data directly to Apple TV at a time.
