Pairing Quarq TyreWiz Pressure Monitor with ELEMNT/BOLT/ROAM
Requirements
Pairing TyreWiz via ANT+
- Access the ELEMNT/BOLT/ROAM menu using the left side button
- Use the Down button on the right side of the ELEMNT to scroll down to ADD SENSOR
- Press the Center button to select ADD
- Press the Right button to select MORE, then shake the TyreWiz to wake the sensor
- Select the sensor type for the sensor you wish to pair
- Hold ELEMNT/BOLT near TyreWiz, then select the sensor using signal strength or ANT ID
- Select SAVE by pressing the center button
- If desired, accept the option displayed to add air pressure as a data field on the ELEMNT
- Repeat the pairing process for your second TyreWiz, if applicable
Configuring TyreWiz Sensors
- After connecting your TyreWiz, open the ELEMNT menu again using the left side button
- Select the TyreWiz from the listed sensors using the ant+ ID stamped on the side
- Once the TyreWiz is chosen, configure by selecting front or rear
- If using 2 TyreWiz, repeat the above process for the second sensor - the ELEMNT will display both front and rear in a single data field split as Front / Rear
