TyreWiz updated to latest firmware using the TyreWiz App
Pairing TyreWiz via ANT+
Access the ELEMNT menu using the left side button
Use the Down button on the right side of the ELEMNT to scroll down to ADD SENSOR
Press the Center button to select ADD
Press the Right button to select MORE, then shake the TyreWiz to wake the sensor
Select the sensor type for the sensor you wish to pair
Hold ELEMNT near TyreWiz, then select the sensor using signal strength or ANT ID
Select SAVE by pressing the center button
If desired, accept the option displayed to add air pressure as a data field on the ELEMNT
Repeat the pairing process for your second TyreWiz, if applicable
Configuring TyreWiz Sensors
After connecting your TyreWiz, open the ELEMNT menu again using the left side button
Select the TyreWiz from the listed sensors using the ant+ ID stamped on the side
Once the TyreWiz is chosen, configure by selecting front or rear
If using 2 TyreWiz, repeat the above process for the second sensor - the ELEMNT will display both front and rear in a single data field split as Front / Rear
