Routes - Share a location from Apple or Google Maps apps [ELEMNT ACE, BOLT 3, or ROAM 3]
As an update to the Take me to function of legacy ELEMNT computers and the ELEMNT app, you can now create a one-time-use route from your current location to a location selected in Apple or Google maps by sharing that location to the Wahoo app.
Requirements
  • An ELEMNT ACE, ROAM 3, or BOLT 3
  • Your computer paired and actively connected to the Wahoo app
  • GPS acquired by the computer
  • An internet data connection (cell data or Wi-Fi) for your phone
How To
  1. Select a location on your preferred map app (search a name, location, or address, or tap to select on map*.
    * In the EU, when using Google Maps, location must be selected from address, rather than GPS coordinates/tap on map. GPS-location oriented details do not parse correctly for transfer.
  2. From the location panel, select the Share** button.
    **Specifically, do NOT select Directions. You are sharing a location to the Wahoo app, to which the Wahoo app/computer will create a one-time-use/temporary route.
  3. Select the Wahoo app logo (as the app you wish to share the location to).
    If the Wahoo app logo does not appear in the list, select ... / More
  4. When the Wahoo app opens and asks 'Share location to ELEMNT?', select Navigate.
  5. A route will be loaded onto the ACE, from you current starting point to the shared location.
Notes/Troubleshooting
  • Your computer must have GPS acquired, or the Wahoo app/computer cannot create a route, because your current location is unknown.
  • Your phone must have a cell data connection, so that the Wahoo app can process/produce the route.
  • You have to select the 'Share' button for a location (address, business name, etc)
    • Not 'Directions' or attempt to share a set of Directions to that location.
  • The route created by this process is one-time-use / temporary. If you wish to create a more permanent route, create a route from the history of this ride, once completed, or sync a route created in a third party app / service.
