ELEMNT ACE ships with all world maps, complete with all map layers, and 5+ GB of storage space remaining for routes, completed ride data, etc. There is no reason to delete any map regions.
Requirements
- A mobile device running the current version of the Wahoo app for iOS or Android with an active data (internet) connection.
- The ELEMNT ACE computer paired and actively connected with Wahoo app on the mobile device.
- The ELEMNT ACE computer itself actively connected to a local saved Wi-Fi network.
Add, update, or delete Maps
From the Devices > your computer > Settings > Manage maps of the Wahoo app you can add, update, or delete maps from different regions:
- Open the Wahoo app on your mobile device.
- Select the Devices tab.
- Select your ELEMNT ACE.
- Select Settings.
- Scroll down to Manage maps in the Navigation section.
- From here you can delete, download, or update maps on your ELEMNT ACE.
Add maps
- Select Add map and then the region you wish to add.
Update maps
- Select the ... (three dots) in the upper right hand corner.
- Select Update all.
Delete maps
- Navigate to the region level from which you wish to delete the maps.
- Select Edit.
- Select the map region you wish to delete.
- Select Delete.
