Mounting the RPM Speed sensor on spin bikes is not supported. For details, please see Is the RPM Speed Sensor Compatible with Spin Bikes?
This setup guide is intended to assist with installing your Wahoo SPEED sensor on your bike and pairing to the Wahoo Fitness app.
How to install the Wahoo SPEED on your bike:
- Slide the Wahoo SPEED pod into the mount supplied. Make sure the Wahoo logo is facing outwards on the flush side of the housing and the back of the Wahoo SPEED faces toward the hook side of the mount. The hooks should be facing downward.
- Slide the rubber shim-strap into the back (the hooked) side of the mount so that the three prongs of the strap fit snugly up against the top two hooks of the housing. The Wahoo SPEED is now ready to fit to the hub of either wheel as per your preference.
- While holding the mount in place on your selected hub, gently stretch the strap portion of the rubber shim-strap around the hub and secure using the bottom two hooks on the mount. When installed correctly, the Wahoo SPEED should not be in contact with any other parts of your bike.
Your Wahoo SPEED is now ready to be paired with the Wahoo Fitness app.
How to Pair your Wahoo SPEED Sensor to the Wahoo Fitness app (iOS):
- Download the Wahoo Fitness app from the App Store.
- Open the Wahoo Fitness app. Make sure you have Bluetooth turned on.
- Activate the Wahoo SPEED by shaking it for a few seconds or if attached to your bike, spin the wheel a few times.
- Select “Sensors” in the bottom left corner.
- Select “Add New Sensor”.
- Choose your Wahoo SPEED from the list of available sensors.*
- Once certain you are connected to the correct sensor, select “Save Sensor”.
- Choose the workout profiles you would like your Wahoo SPEED to be active for (ex. Cycling & Indoor Bike Trainer).
- Select “Done” to complete the pairing & workout selection process.
- Select “Done” in the top left hand corner to exit the Sensors menu.
How to Pair your Wahoo SPEED Sensor to the Wahoo Fitness app (Android):
- Download the Wahoo Fitness app from the Google Play Store.
- Select “Saved Devices” icon on the top action bar.
- Select the plus “+” icon to add a new sensor.
- Once certain you are connected to the correct sensor, select “Save Device”.
- Select “Ok” to complete the pairing & workout selection process.
- Use the Back button to exit the menus and return to the Home Screen.
Your Wahoo SPEED is now set up and ready for action. To use your Wahoo SPEED, start a workout with one of the profiles you paired it with. The Wahoo Fitness app will remember this pairing in the future. You simply need to wake up your sensor and start a new workout to begin recording data!
NOTE: The Wahoo SPEED uses a Blue LED to give instant feedback to the user during the pairing process. These LEDs operate for about 30 seconds before shutting off to conserve battery. The Blue LED represents your connection state and has three modes:
- Slow Blink (about once every second): Wahoo SPEED is awake and not paired.
- 4x Flash: Occurs the instant a connection is made.
- Quick Blink (about twice every second): Wahoo SPEED is paired to a device.
The Red LED represents wheel revolutions. You will see one red blink per wheel turn.
* If a firmware update is available for your sensor, the Wahoo Fitness app will now prompt you to proceed with performing an update. If you do not, the update may be performed later. Sensors with updates available will appear in the menu of Saved Sensors marked with a badge to indicate the update is available but not installed.
