Frame pulled inward KICKR/CORE/MOVE [tsg]
The frame is being pulled inward when I tighten the thru axle.
The CORE is compatible 142mm and 148mm thru axle frames.
If the frame is being compressed inward when you place the bike on the CORE and tighten the thru axle --
  • ensure that the drive side spin cap (Adapter C) is installed on the CORE
  • double check your frame spacing
  • if using the 142mm non-drive side adapter (Adapter D), try the 148mm (Adapter E)
If the drive side spin cap is present and you are already using the 148mm non-drive side adapter, your frame may not be compatible with the CORE.
If your concern is unresolved or you have questions, please submit a support request and our support team will be happy to assist you further.
This is an intermediate step in a troubleshooting flow.
If you have arrived at this page from anywhere other than a previous step in a troubleshooting guide, please find the start of the guide to resolve your issue here.
