Use the calibration function when on a treadmill to have TICKR X accurately measure running speed and distance.
How to Calibrate TICKR X for Treadmill Workouts (iOS):
- From the Workout page, select LINKED SENSORS.
- If already saved, select your TICKR X from the list. Otherwise select Add New Sensor and choose it from the list displayed, then tap SAVE SENSOR, choose your desired workout profiles and tap DONE, then tap the sensor in the list of LINKED SENSORS (as shown below).
- Scroll down to select Calibrate from the sensor menu.
- Select the calibration length and follow the prompts on screen to completion.
Note: even with full calibration, TICKR X tracks best at speeds above 5 mph (8 km/h).
How to Calibrate TICKR X for Treadmill Workouts (Android):
- If already saved, select your TICKR X from the list. Otherwise select Add New Sensor and choose it from the list displayed, then tap SAVE SENSOR, choose your desired workout profiles and tap the back arrow ( ← ), then tap the sensor in the list of LINKED SENSORS (as shown below).
- Select the calibration method and follow the prompts to completion.
