The Wahoo TICKR is a heart rate monitor intended for use with your iOS or Android smartphone or tablet device, or even your GPS watch. In conjunction with your device, it uses Bluetooth 4.0 and ANT+ technology to track heart rate, calories burned, time, plus distance and pace information.
- iOS: This product is designed for use on the Apple devices running iOS 12 and newer
- Android: This product is designed for use with Android devices compliant with the Bluetooth 4.0 running version Android 6 or newer which allow Third Party App Access to Bluetooth 4.0
Note: Wahoo Fitness has not tested complete compatibility with all Android devices matching this description. Please download the app from the Google Play Store to ensure that it installs on your device before purchasing a product.
This product is shipped with the following:
- Heart Rate Monitor
- Adjustable soft strap
- CR 2032 Battery (installed)
- Quick Start Guide
- Important Product Info Guide
Design Specifications:
- Physical Dimensions (LxWxH): 2.75”5"x1.5" (7cmx1.3cmx3.8cm)
- Weight: 1/3 oz (8.5 grams) without strap
- Battery: CR2032
- Battery Life: Up to 12 months
- Sweat Proof: Yes (hand washable strap)
- Water Rating: IPX7 (waterproof up to 5 ft/1.5m)
- Strap Length: Adjustable from 24" to 48” (61-122cm) stretched
