We're all in this together. Due to COVID-19, you may also experience shipping delays. Read More.
Basic TICKR X Info
BASIC TICKR INFO
The Wahoo TICKR Run is a heart rate monitor intended for use with your iOS or Android smartphone or tablet device, or even your GPS watch. In conjunction with your device, it uses Bluetooth 4.0 and ANT+ technology to track heart rate, calories burned, time, plus distance and pace information. The TICKR Run has been optimized for runners and also monitors your running form in three dimensions, alongside other key running indicators such as cadence, vertical oscillation and ground contact time.
  • iOS:  This product is designed for use on the Apple devices running iOS 10 and newer
  • Android:  This product is designed for use with Android devices compliant with the Bluetooth 4.0 protocol running version Android 6 or newer & must allow Third Party App Access to the Bluetooth 4.0 (Smart) Radio
    Note: Wahoo Fitness has not tested complete compatibility with all Android devices matching this description. Please download the app from the Google Play Store to ensure that it installs on your device before purchasing a product.
This product is shipped with the following:
  • Heart Rate Monitor
  • Adjustable soft strap
  • CR 2032 Battery (installed)
  • Quick Start Guide
Design Specifications:
  • Physical Dimensions (LxWxH): 2.75”5"x1.5" (7cmx1.3cmx3.8cm)
  • Weight: 1/3 oz (8.5 grams) without strap
  • Battery: CR2032
  • Sweat Proof: Yes (hand washable strap)
  • Water Rating: IPX7 (waterproof up to 5 ft/1.5m)
  • Strap Length: Adjustable from 24" to 48” (61-122cm) stretched
Contact Support
CALL US
1(877) 978-1112
PHONE SUPPORT
CLOSED WEEK OF JULY 6
(M-F) 4pm-9pm GMT
US?
