Offline workouts sync automatically whenever the Wahoo Fitness app is open and connected to an active TICKR X. If you don't have a strap handy, you can wake the TICKR X by touching both metal terminals on the back with your hand until the blue light flashes. Don't forget to ensure Bluetooth is enabled on your device.
Though workouts under 5 minutes long are not saved automatically, these can be accessed on iOS following these steps:
In the Wahoo Fitness app, select Sensors
Select TICKR X and scroll down
Select Offline Workouts
Select the Download icon on the left to save any offline workout to your history in the main menu.
Please note that while TICKR X offline workouts under 5 minutes are not currently accessible from Android devices, workouts longer than 5 minutes can be imported manually (if necessary) with the following steps:
- Pair and save the TICKR X from the sensors menu
- With the TICKR X actively paired, return to the main menu and select the history button
- Pull down to refresh the page and import offline workouts
