Share an activity to a third party app [Wahoo app]
The Wahoo app can share completed activity summaries (as .FIT files) with a variety of third party app partners.
Third party apps available for workout sharing
How a third party app partner is connected to the Wahoo app/your Wahoo account will differ by app partner. Some of the most popular app partners can be connected by authorizing their connection to the Wahoo app in Wahoo app Settings.  Others can be connected by linking your Wahoo account in the partner's app or web interface. This process will differ between partner apps.
Apps authorized in the Wahoo app
App partner Import plans Import routes Import segments Import summaries Share plans Share summaries
adidas Running           ✔
COROS       ✔   ✔
Dropbox           ✔
FitBit           ✔
Komoot   ✔       ✔
MapMyFitness   ✔       ✔
MapMyTracks           ✔
MyFitnessPal           ✔
RideWithGPS   ✔       ✔
Strava   ✔ ✔ ✔   ✔
Trailforks   ✔
TrainingPeaks ✔         ✔
Xert*           ✔
Zwift**       ✔ ✔
*Authorizing Xert in the Wahoo app allows you to share activities completed in the Wahoo ecosystem directly to Xert, including setting up auto-sharing.  In order to import compatible planned structured workouts to be completed in the Wahoo app or ELEMNT computers, you must also connect your Wahoo account in the Xert app or web interface.
**Zwift can be authorized in the Wahoo app or SYSTM app to share calendared SYSTM workouts to Zwift and sync SYSTM workouts completed in Zwift back to the SYSTM calendar. For more details see Export Wahoo SYSTM planned workouts to Zwift.
Connecting your Wahoo/SYSTM account in Zwift will only sync completed activity summaries between apps.
Apps authorized in the partner app / web interface
Afasteryou           ✔
Bikemap   ✔
COROS       ✔   ✔
Enduco ✔         ✔
FasCat ✔         ✔
Humango ✔     ✔   ✔
Intervals.icu ✔         ✔
JOIN Cyling ✔         ✔
MATS ✔         ✔
Nolio ✔         ✔
Rouvy       ✔
TrainerDay ✔         ✔
TrainerRoad ✔         ✔
Xert* ✔
Zwift**       ✔   ✔
* Connecting your Wahoo account in the Xert app or web interface allows you to import compatible planned structured workouts to be completed in the Wahoo app or on Wahoo computers.  In order to share activities completed in the Wahoo ecosystem, you must also authorize Xert in the Wahoo app.
Authorize a third party app
Authorize in the Wahoo app
Some of the most popular apps can be authorized in the Wahoo app > Today > Account (your user icon in the upper left corner)  > Authorized apps. For details on the authorization process, see Authorize an app partner to sync routes, planned workouts, completed rides, or segments.
Authorize in the partner app / web interface
Other, mostly more newly connected apps / services are connected through the Wahoo Cloud API. To connect these apps / services to your Wahoo account, authorize your Wahoo account in the partner's app or web interface, using the email and password used to log in to the Wahoo app.
Because the authorization process will differ between app partners, we suggest reviewing the app partner's interface, support documentation, and consulting their support team for how best to connect your Wahoo account.
Share a completed activity
Auto-sharing
All third party apps authorized in the Wahoo app can be toggled to auto-share a .FIT file of an activity when it is completed in the Wahoo app or uploaded to the Wahoo app from an ELEMNT computer.
Auto-sharing is toggled off by default.
This is enabled in Settings > Authorized apps > chosen app
All third party apps authorized in the partner app / web interface are automatically shared to the third party partner when an activity is uploaded to the Wahoo Cloud.  Because the app connection is controlled in the third party app interface, auto-upload cannot be toggled off.
Manual sharing
If auto-sharing has not been enabled for a third party service (auto-sharing is set to off by default), or if an activity is completed while the app is does not have an internet connection, you can manually share an activity by:
  1. Navigating to the History tab of the Wahoo app.
  2. Locating the activity from among the activities in the reverse chronological order of the History tab.  You can use the filters to shorten the list.
  3. Select the three dots in the upper right corner of the activity's summary panel.
  4. Select Share activity.
  5. Select Share to connected app from the menu that appears at the bottom of the screen
  6. Manually share from the Activity Sharing page that appears
Social Sharing
You can now share your completed workouts directly to Instagram Stories, download the social sharing generated image, copy the image to your clipboard, or export it other apps natively on your phone.
For more information see Social Sharing [Wahoo app].
Download .FIT activity
The Wahoo app will also allow you to download your activity's .FIT file directly to the device that is running the app.
  1. Navigate to the History tab of the Wahoo app.
  2. Locate the activity from among the activities in the reverse chronological order of the History tab.  You can use the filters to shorten the list.
  5. Select Download .fit activity
  6. The phone's native sharing menu will open, allowing you to download to your phone's file storage directly, or share the .FIT file using available aps.
Troubleshooting
Deauthorize / Reauthorize an app
If a workout is not automatically sharing to a 3rd party app that you have authorized and will not if you attempt to manually re-share, the first step to resolving this should be to deauthorize and reauthorize the app to reset the connection between Wahoo and the app.
For apps authorized in the Wahoo app
Navigate to the app, select the down arrow to the right to expand the section, and then select Deauthorize.
wa-authorizedapps-strava-300.png wa-authorizedapps-deauthorizestrava-300.png blank300x200.png
The app should return to the Available apps list, where you can select it and reauthorize it.
wa-authorizedapps-300.png wa-authorizestrava-300.png wa-authorizedapps-stravaauthorized-300.png
For apps authorized in the partner app / web interface
Because the authorization process will differ between app partners, we suggest reviewing the app partner's interface, support documentation, and consulting their support team for how best to disconnect/reconnect your Wahoo account.
If an app will still not upload a workout after deauthorizing and reauthorizing a third party app, please submit a support request.
