Does the screen work when it's wet?
Yes! The PROTKT is designed to protect your phone in wet conditions. Due to the nature of capacitive touch screen technology, you may experience lessened sensitivity on your touch screen if there is a significant amount of moisture present. If you are having problems just wipe off the water and you will be good to go!
If you're continuing to experience problems with water, we have discovered that applying a thin coating of a water repellent, such as Rain-X, greatly improves the performance of the PROTKT in wet conditions. The coating should be applied to the outside of the PROTKT screen while the phone is sealed in the case. Do not apply directly to the phone or to the inside of the case!
