Shifter + button configuration for KICKR BIKEs / SHIFT
KICKR BIKEs and BIKE SHIFT support shifter configurations to match shifting and gearing options offered by Shimano, SRAM, and Campagnolo.  Multiple shifter and gearing configurations can be created, stored, and edited in the Wahoo app, and the last selected profile will remain in use on the BIKE until overwritten.
Additionally, each BIKE has the capacity for some contextual app control. See Zwift controls for KICKR BIKEs / SHIFT.
Button locations
BIKE and BIKE SHIFT each have a total of 10 buttons on the shifters in the cockpit, in addition to the brakes.bike-buttons-highlightall-800.png
  • 2 shifter buttons on the outside of each brake lever
    • Used for Shimano and SRAM shifting configurations.
  • 1 multi-use button on the inside of each shifter body
    • Used for shifting with a Campagnolo shifter configuration.
    • Used for steering in Zwift (not compatible with the Campagnolo shifting profile.)
  • 2 multi-use buttons on top of each shifter body
    • For BIKE v1
      • Left side
        • Front - Tilt down
        • Rear - Tilt up
      • Right side - app contextual
        •  Zwift
          • Front - Power Up
          • Rear - U-Turn
    • For BIKE v2
      • Left and Right side simultaneously
        • Front - Tilt down
        • Rear - Tilt up
      • Left side
        • App contextual buttons
          • in Zwift
            • Front: Ride On!
            • Rear: U-Turn
      • Right side
          • in Zwift
            • Front: Power Up
            • Rear: U-Turn
    • For BIKE SHIFT
      • Left side
          • in Zwift
            • Front: Ride On!
            • Rear: U-Turn
      • Right side
          • in Zwift
            • Front: Power Up
            • Rear: U-Turn
BIKE v1 and v2 also have a single button on the head control unit on the drive (right) side of the bike.
  • Tap to lock (secure manual only) or unlock (provide app control of) tilt functionality.
  • Double tap to level the BIKE to neutral tilt position.
Available shifter configurations
  • Shimano
    • Di2/Mechanical
    • Di2 Synchro
  • SRAM
    • eTap
    • Mechanical
  • Campagnolo
    • Mechanical
Create a shifter profile
1.  Ensure the device running the Wahoo app has an active data connection.
2. Pair your BIKE or SHIFT to the Wahoo app.
3. Once paired, navigate to Home > My sensors > BIKE or SHIFT
4. Scroll down to the Bike profiles section and select Create bike profile.
5. Select your preferred Shifting and Braking configuration.
6. Select your preferred number of chainrings and chainring tooth count.
7. Select your preferred number of cassette cogs.
shifter-shiftingbraking-300.png shifter-chainring-300.png shifter-cassettecogs-300.png
8. Select Range and select your preferred preset cog range or Custom to select the tooth counts of your preferred custom cog set.
9. Select the back button in the upper left hand corner. The selected settings are automatically saved.
shifter-cassetterange-300.png shifter-cassettecustom-300.png shifter-cassettecogs-300.png
Edit a shifter profile
1. Open Home > My sensors > BIKE or SHIFT.
2. Scroll down to Bike profiles and select the profile you wish to edit.
shifter-editbikeprofiles-300.png blanktrans300x600.png blanktrans300x600.png
3. Select your preferred Shifting and Braking configuration.
4. Select your preferred number of chainrings and chainring tooth count.
5. Select your preferred number of cassette cogs.
6. Select Range and select your preferred preset cog range or Custom to select the tooth counts of your preferred custom cog set.
7. Select the back button in the upper left hand corner. The selected settings are automatically saved.
Delete a shifter profile
2. Scroll down to Bike profiles and select the profile you wish to delete.
3. Scroll down to the bottom of the profile and select Delete profile.
shifter-editbikeprofiles-300.png shifter-cassettecogs-300.png blanktrans300x600.png
