Athlete Profile [Wahoo app]
The athlete profile information can be found on the Account page, which is accessed by selecting the icon on the Today tab in the upper left hand corner. To edit your biometric data from the account page, select the button at the top of the page that contains your icon and name.
First and last name data fields appears in our internal database and use simple text entry.
Biological Sex and Date of birth values are used to help inform your 4DP profile and rider type, 3DP profile and runner type, and other default values. The Sex data field uses a basic drop down list.
The Date of birth field will open a calendar.  Tap the down arrow next to Month YYYY to pull up a scrollable year list, tap your year, then month, then day.
Units of measure for distance, elevation, temperature, height, and weight can be set to metric, imperial, or custom, with each unit set separately.  Height and Weight use simple text entry.
Country uses a text-entry based live search to generate a list for tap selection. Country names are based on current ISO 3166 values.
Help & Support guides, delete account and log out from your profile is at  the bottom of the account page.
