How do I Pair the CLIMB to my Trainer?
Once your bike is mounted on the KICKR CLIMB, you're ready to plug it in and get it paired with your KICKR or KICKR SNAP. Before pairing however, you'll need to ensure your setup meets the following requirements.
PAIRING REQUIREMENTS
PAIR WITH KICKR OR KICKR SNAP
  1. Ensure KICKR CLIMB and smart trainer are plugged in and powered with the blue LED illuminated on the KICKR CLIMB remote.
  2. Press and hold the center lock mode button on the KICKR CLIMB remote for 3 seconds until the center white LED flashes steadily.
  3. Hold the CLIMB's remote near the KICKR or KICKR SNAP until the center white LED flashes quickly, then turns solid. The center white LED remains illuminated and solid while connected and successfully paired to the smart trainer.
  4. Once paired, be sure to update your KICKR CLIMB firmware before riding.
After updating, you're ready to go! You can now use your KICKR CLIMB with any compatible app using unlocked mode.
NOTE: The KICKR CLIMB always starts and wakes in locked (AKA manual control) mode to prevent it from moving unexpectedly. Tap the center lock button on the KICKR CLIMB to enable unlocked mode (indicated by the remote's blue LED moving from the locked side to the unlocked side) for control through any app that sends grade data to your smart trainer.
