How do I update the firmware on my RPM Speed Sensor?
To perform a firmware update:
  • Download the Wahoo Fitness app from the App Store (iOS) or Google Play store (Android).
  • Open the Wahoo Fitness app. Make sure you have Bluetooth turned on.
  • Wake up your sensor.
  • Select “Sensors” in the bottom left corner.
  • Select “Add New Sensor”.
  • Choose your sensor from the list of available sensors.
  • Once certain you are connected to the correct sensor, select “Save Sensor”.
  • Choose the workout profiles you would like your ELEMNT MINI to be active for (ex. Running & Cycling).
  • Select “Done” to complete the pairing process.
Once paired, the Wahoo Fitness app will check for any available firmware updates.  If an update is available, you will receive a pop up notification.  Select Upgrade to perform the upgrade and follow the prompts to complete the process.
