Pair MINI with the ELEMNT app
ELEMNT MINI Bike Computer:
  1. Remove from packaging.
  2. Turn on by pressing either of the buttons located on the front of the device. After first time loading, a QR code will be displayed. You are now ready to start setting up the ELEMNT MINI with the ELEMNT companion app on your smartphone.
iOS
iOS: This product is designed for use on iOS devices (iPhone 4s and newer, iPad 3rd gen and newer, iPad mini, iPad Air, and iPod 5th gen and newer) which support iOS 8 and newer.
  1. Ensure your Apple device has been updated. The ELEMNT Companion App will run more efficiently on an updated operating system.
  2. Enable Bluetooth on your mobile device.
  3. Download the ELEMNT Companion App from the Apple App Store by searching ELEMNT Companion App and pressing download.
  4. Open the ELEMNT Companion App after downloaded. Watch the introductory welcome video or skip to continue to the ELEMNT MINI setup and tutorial within the companion app.
  5. If not turned on already, turn your ELEMNT MINI on by pressing one of the buttons located on the front of the device.
  6. Select Start to proceed with pairing the companion app to your ELEMNT MINI.
  7. Pair your ELEMNT MINI with your smartphone by scanning the QR code displayed on the ELEMNT MINI by placing the ELEMNT MINI in front of your phone’s camera with the ELEMNT Companion App open (there will be a viewing window in the app). If prompted, grant the ELEMNT Companion App access to the camera.
  8. When the dialogue box appears, select Pair to complete the pairing process.
  9. The ELEMNT Companion App will walk you through key setup steps for your ELEMNT MINI
  10. The ELEMNT Companion App will now display the login page. Log in by signing up to the Wahoo Fitness Cloud or use your Facebook login to proceed.
NOTE: Login is necessary to backup your data and sync between devices. This step can be skipped, but will be required in order to view your data on other devices.
Authorize your favorite fitness sites and the ELEMNT Companion App will automatically upload when connected to the ELEMNT companion app.  Alternatively, select Next and add these later.
Complete a basic profile to be used with the ELEMNT MINI. This information will be used to calculate metrics such as calories and HR zones. Alternatively, select Next and add these later.
NOTE: If an update for the ELEMNT MINI exists, you will be prompted to perform one now.       Select Update Now to proceed, or select Later to update your device at another time. Updating at this time is strongly advised as the updated devices will run more efficiently.
Android
This product is designed for use with Android devices compliant with the Bluetooth 4.0 protocol running version 4.3 or newer & must allow Third Party App Access to the Bluetooth 4.0 (Smart) Radio.
NOTE: Wahoo Fitness has not tested complete compatibility with all Android devices matching this description. Please download the app from the Google Play Store to ensure that it installs on your device before purchasing a product.
  1. Ensure your Android device has been updated. The Companion App will run more efficiently on an updated operating system.
  3. Download the ELEMNT Companion App from the Google Play store by searching ELEMNT Companion App and pressing download.
  8. The ELEMNT Companion App will walk you through key setup steps for your ELEMNT MINI
  9. The ELEMNT Companion App will now display the login page. Log in by signing up to the Wahoo Fitness Cloud or use your Facebook login to proceed.
