Thanks for choosing Wahoo!
How Do I See my Shimano Di2 Battery Level on an ELEMNT?
With an ELEMNT paired to your Di2 or SRAM eTap system (instructions here), you can check the battery level by navigating to the sensor in the ELEMNT settings menu directly on the device.
  1. Press the Menu button to open the ELEMNT settings menu.
  2. Scroll down using the side buttons to highlight your electronic shifting system.
  3. Press the bottom right button to select More.
  4. Battery level is displayed on the page.
When the battery level drops below 20%, a pop-up notification appears on the ELEMNT to warning of low charge.
Note: this function may not be compatible with the following electronic shifters:
  • Campagnolo EPS
  • FSA K-Force WE
Contact Support
CALL US
1(877) 978-1112
(M-F) 9:30am-6:30pm ET UK?
UK: +44 800 808 5773
(M-F) 2:30pm-11:30pm GMT US?
