Thanks for choosing Wahoo!
How do I set wheel circumference for my speed sensor with the ELEMNT Bolt (iOS)?
Once your speed or speed/cadence sensor has been paired to the ELEMNT, you can set the wheel circumference to match your wheels/tires.
  1. From the Companion App, select the Settings page.
  2. Under Sensors & Data, select Set Up Sensors.
  3. Under Saved Sensors, tap your paired Speed or Speed/Cadence sensor.
  4. Choose Wheel Circumference
  5. Once on the Wheel Circumference screen, swipe the option for Automatic to off.
  6. Enter your custom circumference measurement or choose a size from the list.
