How do I create a route from history or a file using the Companion App?
You can create a route to sync to your ELEMNT from your ride history or a .gpx or tcx file by using the ELEMNT App. This will only provide the route, and will not give you Turn by Turn notifications.
From Ride History
  1. From the Ride screen in the ELEMNT App, select "No Route Selected".
  2. Select "Create From History".
  3. Select the ride you want to create a route for. Enter the name for the route and hit "OK".
  4. The route will now be listed under Routes.
  5. Tap on the route and choose "Select Route".
  6. Route will be imported on the ELEMNT.
From a File
  1. The .gpx file must be stored on the phone. Find the .gpx file on your phone (in file storage or in email).
  2. Tap the file and choose "Import with ELEMNT".
  3. Enter the name for the route and hit "OK".
  6. Route will be imported on the ELEMNT (cell coverage or wifi will be required).
