Once your speed or speed/cadence sensor has been paired to the ELEMNT, you can set the wheel circumference to match your wheels/tires.
- From the ELEMNT App, select the Settings tab
- Under Sensors & Data, select Set Up Sensors
- Under Saved Sensors, tap your paired Speed or Speed/Cadence sensor, then Wheel Circumference
- On the Wheel Circumference screen, swipe the option for Automatic to off
- Enter your custom circumference measurement or choose a size from the list
