Your ELEMNT is able to pair to almost any Bluetooth or ANT+ sensor to provide additional data including:
- Power meters
- Heart rate monitors
- Speed sensors
- Cadence sensors
- Speed/Cadence sensors
- Muscle oxygen sensors
- Electronic Shifters
Pairing with ELEMNT
Your ELEMNT will pair directly with both Bluetooth and ANT+ sensors. For sensors that are dual band, the ELEMNT will default to Bluetooth unless you follow the steps to pair via ANT+.
To pair a sensor via Bluetooth:
- Wake up the sensor.
- Start by pressing the Menu button on the left side of the ELEMNT.
- Use the Down button on the right side of the ELEMNT to scroll down to "ADD SENSOR". Press the Center button to select "ADD".
- Hold the ELEMNT near the sensor. The ELEMNT will chose the sensor with the highest signal strength and attempt to pair.
- Verify the sensor shown is the correct one and press the Center button to select "SAVE".
To pair a sensor via ANT+:
- Press the Right button to select "MORE".
- Select the sensor type for the sensor you wish to pair.
- Hold the ELEMNT near the sensor and select the sensor based on signal strength or ANT ID.
- Press the Center button to select "SAVE".
Pairing with the Companion App
The ELEMNT Companion App can assist you with pairing your Bluetooth (iOS & Android) and ANT+ (Android only*) sensors.
To pair a sensor:
- On the Settings page of the Companion App, select "Set Up Sensors".
- Hold the device near the sensor and select the sensor based on signal strength, description, or ANT ID.
- Select "Save sensor?" to confirm the pairing.
*Android device must have an ANT+ receiver as part of the phone hardware.
