How do I Calibrate a Power Meter with the ELEMNT/BOLT/ROAM?
Though the ELEMNT, ELEMNT BOLT, and ELEMNT ROAM are capable of sending calibration commands to paired power meters both over Bluetooth® and ANT+, calibrations are most reliable over ANT+. Because of this, we recommended using an ANT+ connection for power meter calibration.
Note: while the ELEMNT/BOLT/ROAM sends the sends and receives calibration commands and data to and from power meters, it has no role in the calibration process itself.
Follow these steps to calibrate your power meter:
  1. Wake up your power meter.
  2. Press the Menu button on the upper left side of the ELEMNT/BOLT/ROAM.
  3. Use the Down button on the right side of the ELEMNT/BOLT/ROAM to scroll to your paired power meter.
  4. Press the Left button to select "Calib".
  5. At this point, the ELEMNT/BOLT/ROAM has sent the command and you will need to follow the calibration procedure specific to your power meter.
  6. The ELEMNT/BOLT/ROAM will notify you when calibration is complete.
