Thanks for choosing Wahoo!
How to Replace the RPM Cadence Battery
  1. Insert a coin, screwdriver, or other tool in the indention on the side of the sensor to pry off the top face plate.
  2. Remove the battery and replace it with another CR2032 coin cell battery.
  3. Place the face plate back on the sensor. Make sure the rubber O-ring is properly seated and the two posts on the bottom of the sensor are aligned with the holes in the face plate.
  4. The face plate should snap back into place, making a complete seal with the bottom of the sensor along the outside perimeter. The LED light should blink, indicating that the battery is correctly oriented and powering the sensor.
Contact Support
CALL US
1(877) 978-1112
(M-F) 10am-7pm ET UK?
UK: +44 800 808 5773
(M-F) 3pm-12am GMT US?
Closed 11/22
