KICKR SNAP Smart Trainer Information and Setup
This page applies to the 2017 KICKR SNAP featuring KICKR CLIMB support and LED indicator lights next to the flywheel, as pictured below.
Please contact support for questions on older versions.
The Wahoo KICKR SNAP Smart Trainer makes indoor cycling a "snap!" It's a convenient, easy to set-up wheel-on indoor bicycle trainer with the realistic ride experience Wahoo bike trainers are known for.
Download the Wahoo App
The Wahoo app now provides device, sensor, and profile customization for the ELEMNT ACE as well as extended features/functionality with notifications, music control, and revised LiveTrack (coming soon).
Note: The ELEMNT app will continue to support legacy ELEMNT computers as we work to migrate them into the Wahoo app.
KICKR SNAP Design Specifications
  • Part Number: WFBKTR3
  • Dimensions (legs open): 29" x 26" (74cm x 66cm)
  • Weight (Unboxed): 38 lbs (17.2kg)
  • Rear Wheel Sizes Supported: See KICKR SNAP Compatibility Article
  • Hub Types: 130/135mm QR, 12x142/148 Thru Axle [See KICKR SNAP Thru Axle Compatibility Article]
  • KICKR CLIMB Compatible: Yes
  • KICKR HEADWIND Compatible: Yes
  • Front Wheel Block: Included
  • Accuracy: +/- 3%
  • Connectivity: Bluetooth®, ANT+
  • Max User Weight: 250 lbs (113 kg)
  • Power Source Requirements: 100-240V~1.5A 50-60 Hz
  • Flywheel Weight: 10.5 lbs (4.8 kg)
  • Maximum Simulated Grade: 12%, -10%
  • Maximum Power Output: 1500 Watts
  • AC power adapter (LTE60E-S2-1)*
    • Input: 100-240V~ AC
    • Output: 12V regulated DC at 5 amps
    • Max: 60W
In The Box
  • KICKR SNAP indoor bike trainer
  • AC Power Adapter
  • Quick Release Skewer
  • Front Wheel Block
Compatibility
Frequently Asked Questions
Using Your KICKR SNAP
Troubleshooting
