What Modes are Available to Control the KICKR or SNAP from an ELEMNT?
  • Level: Select a difficulty level from 1 to 10 with a progressive resistance curve - the faster you pedal the harder it gets.
  • Resistance: Just like adjusting the brake in spin class, resistance mode allows fine-tuned direct control of brake resistance from 0 to 100%. Brake resistance remains constant regardless of speed until manually changed.
  • ERG: ERG mode allows you to set a target power wattage and increases resistance to maintain a constant power output regardless of cadence or speed. In ERG mode, there's no hiding or costing as resistance increases to maintain power output when cadence or speed drops.
  • Passive: This mode allows your ELEMNT or ELEMNT BOLT to be used as a mounted display when riding a smart trainer paired to a 3rd party app. The cyclocomputer displays and independently records metrics from connected sensors during a workout.
  • Route: Route mode allows you to recreate rides or simulate a route on your KICKR with support of terrain features like hills and valleys.
Complete instructions (with screenshots) are available in Controlling the KICKR and SNAP from the ELEMNT.
