Thanks for choosing Wahoo!
Help & Troubleshooting Pairing with the ELEMNT App
The steps below assume you've already followed the standard steps for Pairing with the ELEMNT App.
If you're still having trouble, the following tips are likely to fix your issue.
Start by checking your camera or the ELEMNT/BOLT/ROAM QR Code:
  • Make sure your mobile device's camera is clean and clearly focused on the ELEMNT/BOLT/ROAM
  • Keep the ELEMNT/BOLT/ROAM's screen clear of reflections and debris
Next try un-pairing the ELEMNT/BOLT/ROAM then re-pairing:
iOS:
First remove the ELEMNT/BOLT/ROAM from your phone’s Bluetooth settings with these steps:
  1. Open the Settings App on your iOS device
  2. Select Bluetooth
  3. Locate the ELEMNT/BOLT/ROAM in the list of My Devices
  4. Select the lower case i to the right of the ELEMNT/BOLT/ROAM
  5. Select Forget This Device
Once complete, open the Settings page of the ELEMNT app to select Forget Phone, then Pair.
Note on iOS updates: Un-pairing your ELEMNT/BOLT/ROAM after an iOS update may be required to re-establish a connection following instructions to re-display the QR Code, then re-pairing to the app.
Android:
Choose FORGET PHONE directly from the ELEMNT/BOLT/ROAM’s settings (left side button), then retry pairing.
Contact Support
CALL US
1(877) 978-1112
(M-F) 10am-7pm ET UK?
UK: +44 800 808 5773
(M-F) 3pm-12am GMT US?
