To pair KICKR from the ELEMNT itself:
- Wake up your sensor
- Open the Settings menu by pressing (not holding) the power button
- Highlight 'Add Sensor' and select it
- Place the sensor close to the ELEMNT and you’ll be prompted to save after a few seconds. If you have many close sensors then you will see a More option(bottom right button).
To pair a KICKR from the companion app (iOS and Android):
- Open the ELEMNT Companion app
- Select Settings
- Select 'Set Up Sensors'
- Select the sensor you wish to pair from the "Unsaved Sensors" menu
- Select "Save Sensor"
