Thanks for choosing Wahoo!
How do I update the ELEMNT?
Using the ELEMNT by Itself
Firmware updates for the ELEMNT are installed automatically when a WIFI signal is present. Alternatively, you can manually update firmware from the settings menu as shown below.
  • Ensure your ELEMNT is powered on, well charged, and connected to wifi
  • Once on the home screen, press the power button to bring up the following menu
  • Highlight "SYSTEM INFO" using the right-side scroll buttons and select "OPEN"
  • Highlight "CHECK FOR UPDATES" and select "CHECK"
Follow the prompts to update the firmware and it will download and install if available. Note that automatic updates are only performed prior to powering off to avoid interference with use.
Using the Companion App
When connected to the Companion App, you will also be able to see if an update is available. On the Settings screen you will receive a red banner notification if an update is available to download and install. Follow the prompts to update the ELEMENT.
Contact Support
CALL US
1(877) 978-1112
(M-F) 10am-7pm ET UK?
UK: +44 800 808 5773
(M-F) 3pm-12am GMT US?
Powered by Zendesk
